My thoughts went to that direction as well. There are too much "wet grass" etc. effects called upon with a common denominator: E-field coupling. I'm almost certain my Rx coils will be bifilar with center tap to the signal ground, and Tx will be fed via separate pair.
Now regarding the IB coil systems. I made a LTspice simulation of a DD coil system, with values according to my gut feeling. I tinkered a bit with coupling to achieve some 120dB Tx suppression, and copied everything to show situation with resonant Rx tank, and a non-resonant Rx coil. This arrangement is as such for future experiments purposes - I did not put any target there yet.
Even here It is obvious that the tank resonance screws up phase so badly that any discrimination at resonance is doubtful. Also it is obvious that below resonance there is not much going on that would be any different from a non-resonant case.
So, have fun and play with this. This arrangement will be easy to adapt for concentric coils as well, and of course with more life-like values.
