large coils
Hi The Digger,The Digger, The Digger,
Have you got a capacitance reading for shielding to coil, my large coil has a cap. of about 263pf coil and 146pf coax for a total of 409pf and the 6" has 92pf for the coil and 79pf for the coax for a total of 171pf, the outside dia. of my finished coils with shield is about 16-18mm so yes i agree with the 3mm gap between shield and coil, i use 1 layer of spiral wrap and a double layer of woven shadecloth. It sure sounds like the shielding is the problem i am having, i can't waite to try out your method and i was wondering if you have tried 1/2 hitches all the way round with 12mm gaps as i keep thinking that the connection between your spiral wrapped wire and the single run wire which is just an overlap would have problems down the track. Definetely food for thought, so thanks "The Digger" i have been rejeuvinated.
Regards Ron
Regards Ron
