my 2 cents
For building large coils, the professionals use a multi cable in one jacket. Usually 7, 8, or 9 wires in the jacket and unshielded cable. They will all be different colors. Take one color wire, make it the end to be connected to your feedline, typically coax, then the other end to another color wire, then the other end of that wire to the next color, so you are in effect creating several turns by doing this. That's why on the closeup of the video you saw, it was just one large cable in the PVC pipe.
The large cables are not shielded. Your large coil will not be able to be operated at a very short delay. Probably the shortest will be approximately 30us, therefore you won't have to worry about capacitance effects with the ground and won't need a shield.
Again, you don't want to pot it. Leave the wire loose inside the PVC just as you saw in the video. The coil will be heavy enough with the weight of the PVC pipe. It will be very heavy with potting and there is really no good reason to pot it since you are using it on dry land and not dragging it through water.
This is how the big boys do it
Good luck,
Boattow
Good luck,
Boattow
