BH Fortune Hunter Problem - Help Please
  • BH Fortune Hunter Problem - Help Please
    Hello tech guys. I have a 2003 model Bounty Hunter Fortune Hunter metal detector. This thing suddenly turns itself off after about 15 minutes of use. I also have to switch it on and off several times to get it to come back on. It works surprisingly well when it is working right.
    I cleaned the circuit board and cant see anything wrong but I'm an amateur. Can anyone tell me what to do? Any ideas as to what might be wrong? Any help or advise would be greatly appreciated.
    what batt you have on a board? 9V battery or?
      It takes 2 nine volt batteries
        It does sound like a power issue or a connection problem. I would hook up a power supply instead of the batteries powering the unit. Of course you are limited to keeping the detector on the bench. This would give you a stable power source that would also allow you to monitor the current draw.
          Thank you. I will start there.
            DD is right. the 9V socket is very poor. i told how to change the batts on STEP UP converter bipolar with 18650.
              i ask forum owner to increase a time for comment correction to 1 hour.
              Bounty Hunter Tracker IV mods? - Geotech Forums (geotech1.com)
