Oscilloscope
  • #46
    I would avoid a hybrid CRT scope. I've had a few in the past (mostly Tektronix) and they've been problematic with glitchy digital operation. I would either suggest an all-analog CRT scope or a digital LCD scope. The Tek 465/475 were one of the best analog scopes, built to last. The later 2200/2400 series are hit-or-miss, some are good but we had a lot of 2465's go bad at Analog Devices. Kikusui generally made good analog scopes (used them in college) and had good luck with a batch of Hitachi scopes I bought at an auction.
    • #47
      I've been using a Rigol DS1052E. Don't know how it compares with other scopes in it's price range. Works for me. Have used analog and digital scopes at work. One advantage of a digital scope, can see the whole trace when looking at longer record times(looking at integrator noise with 500ms or 1second/division as an example). Analog scope with persistence would work also. I haven't seen a disadvantage using my digital scope playing with metal detector circuits.
      Digital scopes can alias. If trace doesn't make sense, change the time base to see if trace changes.
      • #48
        Thanks to all, that person never answered me back after i asked how he tested with no probes. The one from craiglsit
        • #49
          ... I would either suggest an all-analog CRT scope or a digital LCD scope...
          Correct.
          I was not in (financial) position to buy good enough digital LCD scope, so i picked and bought very good enough all-analog CRT instead.
          For what you get from all-analog CRT scope; you'll need 3x ... maybe 5x more money to pay for digital LCD scope.
          • #50
            My suggestion also to look after those models.
            I have two 475A (purchased as used), both in mint state, one for work, the second for spare parts.
            Purchasing suggestion:
            If possible, buy used analog scope from knowledgeable person, who is able to calibrate such scopes.
            Do some search and talk to sellers about their competence in field (of scope servicing).
            If possible, avoid purchase valuable instruments from ignorant garage/yard sale resellers, without
            prior quality check.
            Rigol is between "chinese" one of most decent brand.
            Old DS1052E can be even tricky "upgraded" to 100MHz.
            • #51
              This can be firmware upgraded to 200mhz from a 70mhz model
              some come shipped already done, there is a video of an electronics person showing this, learn electronics is the name i think.
              I was looking at this one as a maybe
              Hantek DSO5072P, $215
              • #52
                Rigol scopes are also known for hackability. I upgraded mine, it was quite easy.
                • #53
                  Some users report problem with (USB linked) software under Win 10.
                  If PC real-time analysis is important to you, check first if problem is real and solved.
                  • #54
                    Rigol are good inexpensive digital scopes and are well supported, at least in the US. DS1054z is a good 4 channel model and 50 MHz bandwidth which should be more than enough for detector work. If you can live with two channels the DS1202 is less than $300US.
                    Analog oscilloscopes still have advantages particularly for beginners. I am not aware of any current production models that are of good quality though. You should be able to find good used older oscilloscopes BUT you will have to know how to fix them yourself. They can be fixed and there is help but the good ones are all old. The Tektronix 465/475 were built back in the lates 1970?s that is 45-50 years old. Thinks break after that amount of time.
                    • #55
                      I do not recommend PC based scopes. They do some things well but the update rate is usually poor and having to use a PC as a display is a pain.
                      • #56
                        hanks, i will do that, only interested in md or coils right now
                        T
                        • #57
                          ll look at rigol next on amazon thanks
                          I
                          • #58
                            o the pc based run off of there mother board, thats why there slow, or do they use my pc speed, so a more ram or memory could fix that
                            d
                            • #59
                              You don’t even need to hack the Rigol, they have offered all the scope options for free a couple of times this year.
                              • #60
                                They do use the Pc to proceess and display the data. If you have a faster PC it will help but the software on the cheap stuff is generally poorly written.
