Dummy question
  • Dummy question
    I see this psu. I need advice how to increase current, I need maximum current, can I replace 560R to 1R to get max current? I appreciate any suggestion. Thanks
    560R does not have a relation 'to get max current'.
      Thanks for respond master KT315, I'm not good understanding for this schematic, is it possible to get more current, by changing which components?
        What current do you want to increase, and by how much? The 78L regulators are only good for 100mA.
          if you want more current run out from this sch. https://en.wikipedia.org/wiki/Efficient_energy_use
          it is good just for small power, not for big.
            Thank you Mr. Carl, I need 150mA does changing both transistor to 2N2905A + 2N2219A will do?
            Add: I have L7805 / 7905 for this, just want to get maximum 555 can do, without changing my pcb
              Thank you for the link! Mr.KT
                No, you will need different regulators, the 78L can only supply 100mA. Then you need to look closely at the charge pump. The output caps may need increasing, the frequency may need to be higher, the diodes & transistors may need to be beefier. There is plenty of info on the web on how to design charge pump circuits, probably including some simple calculators.
                  Thanks a lot. I really appreciate for your time Mr.Carl
                  I have to learn more. I was going to put dc to dc converter, 12V to +/-5V but this positive ground confusing me, need more experiment. Regards. Taufik
