Originally posted by der_fisherman
View Post
I just tried blindly starting it and tried to create a schematic and place a transistor. Nice "Drop" button sitting there -- maybe drops a part onto schematic?.... No, drops (deletes) parts from the master list...!!!???? I guess I'd better RTM, but that seems like a dangerous button. Probably a way to restore it, but I tried reinstalling. No luck, so quick read of the manual -- "Library|Use" command is used to load the library into the list... whew.
The manual doesn't seem to let me copy and paste text -- gives an error "Invalid Annotation Object" -- are they protecting the manual???
Anyway, on page 110 it says:
Set the Grid
The grid of schematic diagrams should always be 0.1 inch, i.e. 2.54 mm. Nets
and Symbol connection points (pins) must lie on this common grid.
Otherwise connections will not be created between nets and pins.
So why set the grid at all? Shouldn't it be hard-coded to .1 inch? Seems a strange statement.
I'm exploring and trying to see how to display the "grid". Haven't found it yet.
When drawing schematic wires, sometimes it is nice to have a "cross-hair" cursor that extends across the width and height of the window, so you can line up wires and connect them. I haven't found how to do that yet.
I also had difficulting making the wire-draw mode terminate a line! In ExpressSCH you right-click to finish a line before starting another disconnected one. Double-clicking seemed to do it in Eagle, but maybe there is a better way. Double-clicking is less controlled for placing the end-point of a wire. Probably a keyboard key is available to hold when clicking.
Also have difficulting stopping placing parts -- it's a mad part placer, what's the quickest way to get back to a selection cursor? In fact, which icon is a simple selection cursor? I really resent programs that deny you a simple selection cursor for exploring properties, moving objects, etc.
The actual look of the Eagle schematic drawing will take some getting used to -- some of the symbols and colors don't read easily for me. Probably can customize colors no doubt.
So lot's of learning curve for me with Eagle.
I previously looked at DesignSpark also, which was a wild ride and seemed more buggy than I expected. I think it is a young program. So far I wish ExpressSCH and ExpressPCB had a few more features (including import, export, and PCB checking. It does have schematic checking).
( aaaargh me hearties.)
Oh, you thought "Drop [library]" meant Drop [part on schematic]?! That's too bad. (Do you want to talk about inconsistency?)
