Hi Damiafix.
Nowhere is not mistaken. Already work in the past suggested a lower value R6.
For Test3j.... of Information was to verify the operation of V / f totally alone!
Now you do not measure the voltage at Pin16 longer because I will never = 0.
You can measure the voltage at Pin14/15 but there is no such need.
You should be guided by the value of the measured signal indicated on your Analyzer logical, there is more transparent because of the exponential scale.
When the signal = 0, D0 = 0, R6 = 0 I hear the sound of about 50 Hz plus harmonics, but no clatter, clicks that interfere with listening.
With your last test you can hear that with the increase in the frequency of the sound signal increases up to several kHz. The signal is clear and constant! Super!
Compared with R6 = 5Kom, call all the time clicks, at the beginning of the scale there are only cracks and the maximum rated output is only a few hundred kHz, is unpleasant, difficult to distinguish the increase of frequency.
It does not matter that this is a very low frequency, it is useless with a signal from 0 to 25%.
And it is a signal of low value should be well distinguished because it testifies to its sensitivity.
It probably is a bad translation into English, but you do not need a MAG when you stand next to a large treasure chest, or looking smashes his head against the tank, because then you hear it!
You need high sensitivity to small signals when something is deeply buried. Then count the frequency of large-scale extension in the beginning, that you can quickly locate anything! So a large slope (value) Hz / mV.
Note that the two FGM-3 differential and signal work should be small under normal conditions (specificity gradiometer work).
You can leave your R6 1Kom value for regulation in the field of exploration, I'd left the resistor to GND 2.2 Kom. Will provide an initial higher frequency, then adjust R6 to taste!
Note that the MD type of BFO are essentially analog outputs (at least all the old), so that their sound is pleasant, without a large amount of harmonics, and can be adjusted to the frequency of several Hz.
We are happy to accept criticism, but spubuj my ideas.
Best regards Chris.
Why would you smash your head when the sensitivity of the treasure chest, you have to dig it!
Best regards Chris.
it's much sensitve at the probe movements and the rotations on the vertical axes.
