Silver Sabre Plus Modification
  • Silver Sabre Plus Modification
    I recently pick up a Silver Sabre Plus and would like to install a potentiometer for adjusting the ground balance so I can use different coils.
    I saw on Gary's detecting fourm a modified Silver Sabre Plus.
    http://www.garysdetecting.co.uk/sabre.htm
    The detector had a pot installed for ground balance and switch mounted externally for activation of a "Boost circuit".
    I contacted both Gary and the firm that did the modification:
    http://www.pentechnic.co.uk/index.ph...iewDoc&docId=6
    but the modification is no longer available.
    Does anyone have a schematic and instructions/parts list to perform these modifications?
    I searched through the Geotech modification forum and found a few threads but nothing specific.
    The Geotech threads I searched were:
    http://www.geotech1.com/forums/showt...t=silver+sabre
    http://www.geotech1.com/forums/showt...highlight=silver+sabre
    http://www.geotech1.com/forums/showthread.php?13189-Turn-Tesoro-Silver-into-Eldorado&highlight=silver+sabre
    The mods are still posted !!! I have them downloaded somewhere too ?
    Let me search around , I am sure others on this forum have the files archived also .
    Regards..............Eugene
      Thank Eugene.
      Sincerely,
      Alan
        I did not find the files yet . So I put together what you need to do the work yourself .
        See the 3 attachments I posted . As you can see on the photo of the Silver Sabre Plus you have 2 possible spots on the front panel you can mount your 10 turn Bourns [or equivelent] 100 k ohm precision potentiometer . Then see the schematic where you will carefully desolder the old pc mounted trimmer pot , next to LM393 on the left side of the schematic .
        But first read Forum Member Sven's Excellent article on "Cibola GB Mod " . It should help you if you need it and is just a great article to read too !!
        This should get you started , After you disconnect the battery of course !! LOL
        Best Regards....................Eugene
          Silver Sabre Mods
          Thanks again - Eugen.
          I need to order the 10 turn potentiometer for the B circuit. I'm also consider adding a pot to the internal threshold trimmer pot. Know I need to search out the "Boost Circuit" modification that was done by Pentechnic.
          Kindest Regards - Alan
            I posted how to do this a long time ago on here. you need to pull the Bottom (gnd) of the threshold resistor 1k5 I think, change to a 6k8 and connect to NEGATIVE rail.
            Thats me done. I'm off for another 6 months now, if I bother to come back at all.
              Sean:
              Thank you for help.
              Alan
