Q:"I can't see ANY different in performance.....the Deus isn't very difficult or sensitive to a good Null"
That's the point. The level of null makes absolutely no difference to performance until it is too high, then the machine will be awful / not work at all
One thing: That switch you have on you new box, is it in series with the Li cell? I'm thinking it may not be a good idea if you accidentally try charging up the coil with the Li cell disconnected. I doubt it will do any harm, to be honest: 5 Volt less a Schottky diode drop of 0.2V isn't seriously over-volts. One possible idea may be to fit a double-pole switch, and use the second pole to disconnect the + (or -) charging socket wire.
