Originally posted by Beav
modification ATX
Really interesting. Must ponder on it. But must say the iron check stands out. Wonder what tp special is used for? And it uses multi period tx ! ? One long and one short, with the short peaking at just under 2.5A.Originally posted by Mechanic View Post........
Here is the timing pulse train...[ATTACH]34716[/ATTACH]
Cheers Mick
Thank you for sharing, Mech !
Hi MickOriginally posted by Mechanic View PostHi Wm6,
Could be something along those lines, however both sides of the tx coil need to be switched to the rx inputs while no tx is happening.
Did you measure inductance of TX coil part? If it is about 250uH / 0.6R, then drawing I posted could be proper.
