Regarding this audio amplifier - although the circuit now works, I was a little concerned about removing R6 and R11. Mainly because (if this has been traced from a PCB) then the implication is that they should probably be connected somewhere else. :confused:
Based on my previous comment that this detector appears to be designed to work with a Tesoro coil, I had a look at the Bandido audio circuit. Then I was even more certain that it is loosely based on a Tesoro design. The only difference is the power supply voltage. Hence, I think the intended circuit should as follows ->
Basically, R8 and C30 have been drawn connected to the wrong side of R11.
This make more sense.
