Originally posted by Ismael
View Post
Your engineer was right, minelab isn`t it,...they incorporate some sine wave so the "edges" are "rounded off".
When I was designing the PI back it '99 I had a similar problem, at first the engineer said that maybe the switching wasn't real square-waves, I found out it was the damping resistor. Changed that and no more hot FET. I would say that the FET is just not compatible enough. Stick with the 840 can't really see what you would gain with the one you are using now. A FET should not get real hot if everything is designed to suit it. You could do like I did and change the dampening resistors (remember they use 12+ in the 2000!)
we all knows that
and they spent about all the residual fuel just when the lander touched the Moon... big math calculations... oh yeah !
