XL500 sample timing
Hello colleagues have published the poster that Micheal almost complete. problem is that I can not find 2n5566 moha you replaced it with something else. 704 also thank
Please read the forum rules -> Basic Rules of the ForumsOriginally posted by Emiliano_070 View Posthola Micheal tengo casi terminado este placa la quie se muestra un la imagen una duda .:el resistor 704 se podra cambiar con alguna otra cosa
XL500
coke can..............................................7 5(80cmvery faint).. (very very faint at 90cm)Originally posted by Micheal View Postjust a correction I will add is the ring was supposed to be (very very faint at 30cm)
14kt goldring same ring as above test............26cm(very very faint 40)
20cent australian coin.................................37cm(very very faint 40)
$1 australian coin.......................................35cm(ve ry very faint 39
Hi,Micheal, please make a video and post it here to see how work your HL 500.Sensiviiti not the most important parameter for metal detector! G.L.!
yeni thread baslattim sana burdan devam et ...http://www.geotech1.com/forums/showthread.php?t=16901
private message gonderdim sana
selam mustafa usta kafama takılan burda iki adet XL-500 şeması var, 181. iletide ki şema da alıcı katı farklı op-amp kullanılmış. sende ki devre hangisi? hangi devre daha verimli ise onun üzerinden çalışmak mantıklı değil mi? Son olarak ta bu cihazlar satışta ise yasal olarak bir sorun çıkarır mı?Originally posted by Micheal View PostFIXED
http://www.google.com.au/language_tools?hl=en Ingilizce tercume ihtiyaclarini bu linkden yapabilirsin...yeni thread baslatsan daha iyi olacak kardesim.....kolay gelsin
FIXED
Ahmet, I also don't know English but use Google machine translator.Originally posted by ahmet19 View PostPCB scheme was okay. Please if there are mistakes, we fix the errors. I do not know English. I'm sorry.
Fine operation! Thanks! Remove video on the standard purposes (a coin 1еvro? a Coca Cola tin...), or write maximum possibilities of this instrument
PCB scheme was okay. Please if there are mistakes, we fix the errors. I do not know English. I'm sorry.Attached Files
wow this is interesting looks like good work......have you made it yet
For ahmet19
For development - the big respect! But it would be desirable to learn about results (sensitivity, a ground, discrimination). If it is a noncommercial variant, write please more information. In advance I thank.
Originally posted by smity View PostWhat is "XL-500 DIGITAL PI"? Who repeated it? Characteristics? A photo? Video? PCB? Software? Coil? Or it simply theory?
hi
I designed the XL-500 digital. If you want to do if the PCB of my stock. Software no problem. I've made a similar escape attempt. I made such an analog circuit and digital delta pulse.
I'm ready for my XL-500 PCB. But will you make it. I also write software.
For ahmet19
