Yes, the CA3140 is used in a differential mode, but the + and - inputs are fed at different times. The non-inverting input gets the
first,"target" sample. The inverting input subtracts the second, "noise" signal which has been delayed by time t=RC,
the 150k and 1nF on the second os. Because we subtract the 'noise' signal from the sum 'target plus noise', theoretically we
send only target to the following stages!
Ok! Let's see if I have this right.
Sample one is taken and subtracts noise .
Sample two 15 us later is taken containing noise plus target signal.
Q: Why is the target signal not present in the first sample?
I will try to verify L of coil with this method.
http://www.coilgun.info/theoryinduct...inductance.htm
