hi deemon.
you have done a good job.
congratulations.
You seem to be very advanced in electronics.
Would you tell me two things if this topic is still active?
What is the core of TP1
which city are you from ?
Square wave Pulse Induction
Science fiction is not suitable for this topic ...Originally posted by Hayden View PostI would like to see some expansion on that "spark gap" theme. Just changed the plugs in my old pickup and have 6 Autolites ready to go! Have you ever "fiddled" worms? Stick a iron rod into the ground and vibrate it and the worms just bubble to the top and you pick them up and put them in your bucket. I want to see a "gold fiddler" that you just stick in the ground, turn it on, and the nuggets bubble to the top and you pick them up and put them in your bucket
Hey, you use the heel of your hand bumping your pan to make the gold climb out of the black sand don't you? LOL!
Just forgot to add two parts to the circuit
I mean the protection diodes ( D1,D2 ) connected in parallel to TR1.3 ( current transformer output ) . Although they are not needed in a normal operation , it's better to keep them in order to prevent the op-amp inputs from burning by excessive voltage in case of preamp overload or other possible situations during our experiments ....
Here is the circuit of the balance chain . The circuit has been tested and really working , all the pictures of balanced signal in this topic has been provided by this manual balance chain . As we can see , it works as I explained before , the only "strange" thing here is TR2 transformer with two variable resistors ( VR2 and VR3 ) . The function of these parts is compensation of the parasitic signal being produced by eddy currents in the search coil wire . The coil "feels itself" , as I explained before , and this is why we need to cancel this unwanted exponential decaying signal , adding the anti-phase correction signal from the TR2 transformer . Adjusting the duration ( time constant ) and amplitude of this correcting signal we are able to suppress it completely .... by the way , in the previous post by Mickstv we can see the pictures of the real signal - and a very little "spikes" on the very beginning of the every half-period of current wave ( upper trace ) is what I'm talking about .
C1 and R2 are compensating another issue in the real world - I mean a stray capacitance of the search coil winding and a parasitic conductivity of its wire isolation . Athough both factors are noticeable only in a flyback pulse intervals ( that must be blanked during the signal processing ) , being proportional to a flyback pulse voltage and its derivative - we need to suppress them too , in order to avoid the preamp overload by this high-speed signal .... so in reality we can obtain a perfect balance in a wide frequency range - from 1 kHz or even less ( square wave fundamental frequency ) up to several hundreds of KHz . And due to a symmetrical preamp configuration we can obtain the output signal either single polarity or balanced , if we need it for a further processing .
The power supply is 12v p-p generated using a high side half bridge + micro. The top waveform is TX current measured across a 0.1 ohm resistor.
Originally posted by deemon View PostOf course I can , Mick - I didn't do it only because it haven't sense without a working power chain . But now , when you have the power chain working - it's a time to make a perfect balance
I need a little time to draw and scan it - so tomorrow I will post the circuit ....
Thanks Deemon. I'll also post up some oscilliscope pictures over the weekend.
Of course I can , Mick - I didn't do it only because it haven't sense without a working power chain . But now , when you have the power chain working - it's a time to make a perfect balanceOriginally posted by mickstv View PostHi Deemon, in post 51 you have a picture showing the discrim_idle, were you still using the current transformer method ? also just wondering if you could post the preamp part of the schematic (surrounding the current transformer) and explain how you got the output shown in the first picture on post 51.
Mick.
Mick.
By the way , as we a talking about a CC compensation feedback ( tilt control servo loop ) in the topic about GPZ 7000, I want to show how I usually do this in my CC transmitter . My idea is to measure the coil current just before the flyback interval and the current just after it , compare them ( subtract and integrate ) and perform a control action to the kick circuit ( increase or decrease the kick voltage ) , in order to maintan both currents ( before and after ) equal . So , it's a classic servo-loop . The most interesting in this circuit is a current sense method - I use here the same energy exchange mechanism as I do in the power chain
. Energy that has been stored in the little probe coil - then being converted to the capacitor voltage during a quasi-resonant process ( so this voltage is directly proportional to the coil current at the moment of the power chain switch ) , and I utilize the fact that switching ON a positive current gives the same coil response that switching OFF a negative current ( and vice versa )
- the principle is shown on the pictures .
Originally posted by deemon View PostI just sent a reply to the private message from mickstv , but received this notification
The following errors occurred with your submission
- mickstv has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
Because the question was about this square wave TX circuit , I post the answer here -
This voltage is easy to calculate - the transformer divides input voltage proportionally to its turn ratio ( shown on the circuit ) . If you connect the power supply generator to +12 V battery , you'll see 12 volts (peak to peak) square wave on the primary coil of the TR1 ( TR1.1) . So the voltage on the TR1.2 ( turn ratio 1/5 ) must be 12/5=2,4 V ( p-p ) . And on TR1.3 and TR1.4 it must be 12/4=3 V ( p-p ) . The signal shape must be ideal square wave on the all windings of the transformer .
P.S. Anyhow , it's better to ask and answer the questions here - all information about the circuit may be useful for somebody else .... and the forum topic does have enough free space
This voltage is easy to calculate - the transformer divides input voltage proportionally to its turn ratio ( shown on the circuit ) . If you connect the power supply generator to +12 V battery , you'll see 12 volts (peak to peak) square wave on the primary coil of the TR1 ( TR1.1) . So the voltage on the TR1.2 ( turn ratio 1/5 ) must be 12/5=2,4 V ( p-p ) . And on TR1.3 and TR1.4 it must be 12/4=3 V ( p-p ) . The signal shape must be ideal square wave on the all windings of the transformer .Originally posted by mickstvHi Dmitry, Thanks for the reply. Just one other question that you may have posted, If I connect a cro across TR1.2 (no TX transistors fitted) what would be the p-p voltage of the square wave.
Hi Davor
It's a pity , but I haven't enough time to finish a working device , based on this idea .
But I'll finish it , anyhow ...
