Originally posted by Tinkerer
Square wave Pulse Induction
HI Tinkerer, thanks for that, I'll send you a PM so I don't pollute this Thread any more.
Hi Mick,Originally posted by mickstv View Post
Thanks Altra, thanks for the links to read. I've been looking at all the CCPI info on sites and I think I might have play with the AMX or Moodz circuits. I have some ideas around them relating to current comp.
BTW what is the BP THS ?
I would be happy to talk about the AMX, as I did quite a bit of work on it.
- Likes 1
Thanks for that. Looks very interesting. Time to get the soldering iron going......
THS is Truncated Half Sine. It's something John Earle and Carl were working on at Whites.Originally posted by mickstv View Post
See pdf in first post
- Likes 1
Hi Mick, everything I did is in post #90. About the same time I became interested in BP THS designs and that has kept me busy since.
I never attempted auto current compensation manual only. In general, I wasn't happy with how the current compensation was implemented during the transition and the additional torroid etc.If I revisit the circuit, I want to explore the method used by Bruce Candy. He describes a low voltage pulse of about +/-2V right before the Tx pulse changes state, can compensate for current losses. John Earle also used a low voltage pulse to maintain the current at a steady state.
Hi Mick, everything I did is in post #98. About the same time I became interested in BP THS designs and that has kept me busy since.Originally posted by mickstv View Post
HI Altra, Just wondering did you continue on with this design ? Also did you build the auto current tilt and how did it go in real world situations ?
- Likes 2
HI Altra, Just wondering did you continue on with this design ? Also did you build the auto current tilt and how did it go in real world situations ?Originally posted by Altra View PostThese photos show the kick. Blue trace coil current, Yellow V coil. Green Kick voltage. Scope ground= B-. One thing I changed here was D6, D7 to faster diodes MBR160's.
Got it, I was looking at the diodes on your circuit.
I have original Minelab SD2200 DD Coil, I've measured and here is the data:
The 2 connections are inside the plug, so If I remove the bridge wire (1 and 5 pins) this may give separate TX/RX shield if these are not also connected inside the coil as well /your coil seems to be that way/
I changed D6 and D7 on my circuit from Deemon's original design. He specified 1N4007's, attached is his original drawing.Originally posted by eclipse View PostYou mean D5 and D6 /UF4004/?
How do you connect the TX shield, it should be connected to -B? In the mean time the RX shield seems has to be connected to GND. Perhaps a modification inside the coil or the connector /original Minelab coils/ is needed?
On the minelab gpx coil, I have the tx cable shield connected to B- and Rx cable shield to AGND. I believe the coil shield is connected to Rx cable shield internally? My coil has the connector removed.Attached Files
You mean D5 and D6 /UF4004/?Originally posted by Altra View PostOne thing I changed here was D6, D7 to faster diodes MBR160's.
Can you show the waveform on the kick circuit - between Q4 and Q5 ? What is interesting - how does 2N2222 perform it's task ...Originally posted by Altra View PostThe DC resistance is less than 1 ohm. I have tried coils with litz, enamel and Teflon all worked. 300uh to 1500uh. The difference is efficiency and output power. If you want me to try something let me know.
It's good ! But I cannot find on the circuit the DC resistance of the TX coil ... and another question - did you use Litz or simple wire ?Originally posted by Altra View PostHI Deemon
It starts without problem. I did deviate from your design. Coil 300uh and 4.7nf cap, power supply 10v. Lots of improvements to be made.
HI Deemon
