Sandbanks
  • konan
    You can see pcb, electronic schematic with correct parts and look how it seen when is finished there http://www.skrivenoblago.com/viewtopic.php?f=27&t=106
    J think that mast be registred to see...
  • Geo
    Originally posted by Morgan View Post
    I start this project 15 years ago,i get schematic from old electronics book. I stop construction becouse not find E176 transistor anywhere,now its time to finish the project,but i want to use 1mx1m coil.
    Ypu can use a 1x1 coil at this detector without problems. The delay of this is 50us so you don't need to shield the coil.
    Good luck
  • Morgan
    Pulse Induction
    This version is better.
    If you will construct the original one, you must find the metallic LM709, not the plastic. I constructed it before years.
    LF357 who used by Ivconic is much better.
  • Morgan
    Originally posted by DIRCEU View Post
    Hi! Morgan
    Use FET channel P only.
    other equivalences:
    2SJ 103 2N 5460 2N 5463 2SJ 105 2SJ 104 2Sj 107 2SJ 108 2N2606 2N5797 2SJ72 2SJ 110 2sJ 111.
    PS.: J 176 is the same 2SJ 176.
    DIRCEU
    So many equivalent transistors !!!
    Thanks a lot,this solve the E 176 problem.
  • DIRCEU
    But E 176 or J 176 are dificult to find here...
    Do you know some other equivalence transistor ?
    Hi! Morgan
    other equivalences:
    DIRCEU
  • Geo
  • Morgan
    Transistor
    You might to look at this alternative version from Ivconic.
    Thank you
    I will analize this new version circuit
  • Morgan
    Transistor
    Hi! Morgan
    Yes. You can use HEF 4011 BP in IC 7 position.
    Only IC 3 is a unbuffered tipe (CD 4011 UB)
    In position TR 6 use J 176 (P-channel switch)
    2N 2646 is a unijunction transistor. Do not use it there.
    Best Regards
    DIRCEU
    Sorry,my mistake,i mean 2N3919,in replacement for J176.
    What you think ?
  • Qiaozhi
  • Morgan
    Transistor
    Hi! Morgan
    Best Regards
    DIRCEU
    not find this transistor,i see in other Sandbanks shematic 2N3920,this one i can get
  • Morgan
    Sandbanks PI
    Hi! Morgan
    Best Regards
    DIRCEU
  • DIRCEU
    Hi! Morgan
    Best Regards
    DIRCEU
  • Morgan
    Sandbanks PI
    No - these are not the same.
    The 78L05 ia positive 5V regulator, and the 79L05 is negative 5V.
    Hello
    I start the Sandbanks project many years ago ,now i want to finish. I have two questions for you.
    IC 7 can be HEF 4011 BP or need to be the same as IC 3 (CD 4011 UB) ?
    TR6, reference E 176 can be replaced by 2N2646 ?
  • Morgan
    Sandbanks PI
    Originally posted by Janotaking View Post
    The OPA237; OPA2237; OPA4237 are all equivalent to the LM7091? So I need to get the SO-8 single/dual that haves four legs xD Isn't it? And the TLE2021A is equivalent to the Tr6 -> E1761? ok.
    I've got the HEF4011BP that is the buffered type, but I can still use it for the IC7 correct? The IC7 is a buffered one isn't it?
    Now, the IC8 and the IC2 I've used a L7812CV for the IC8 its correct? And for the IC2 Ihave a L7805CV is that equivalent or the same as 79L051?
    Ok guys, thanks for the big help, I finally gone make a metal detector I hope it works
    Thanks a lot again. Stay cool, bye.
    Hi
    You still make confusion with nr of units and values,you put nr of units mixed with component value...Ex. E 176 (1) one unit ,component reference is E 176,see in schematic,not in parts list becouse is wrong.
    I have the same troubles...Start the project long time ago and now want to finish.
  • Orbit
    Without transformer.
