PCB here
Hi fellows. You could teach how to program atmega with arduino.Thanks
Originally posted by green View PostSome of the 1/4 and 1/2 watt resistors have a 250 volt working voltage. Would it be a good idea to series 2 or 3 resistors to get the correct ohms and watts when the peak voltage is over 250 volts or is the high voltage spike so short that it doesn't matter?
Yes its always a good idea to run components within specs so with a typical PI flyback voltage of about ~400 volts 2 or more in series will over come the break down problem,
I find that excessive heat kills resistors , at least with my projects, so building for power so they don't run too hot is also important .
Some of the 1/4 and 1/2 watt resistors have a 250 volt working voltage. Would it be a good idea to series 2 or 3 resistors to get the correct ohms and watts when the peak voltage is over 250 volts or is the high voltage spike so short that it doesn't matter?Originally posted by 6666 View PostYou can build the resistor buy parallel and series resistors to get the needed wattage
Good idea, never flash in my mind . ThanksOriginally posted by 6666 View PostYou can build the resistor buy parallel and series resistors to get the needed wattage
i need hex files but it shouldn't counter. if you have hex files can u send me ?
What if i use 0.5 watt 390 ohm 1% resistor for the damping ,is there will any problem? Cant find 1% for higher watt.
