Wouldn't burning the bootloader into the atmega328 slow down the chip ?, I dont know thats why I am askingOriginally posted by ivconic;209441[FONT=comic sans msSmall tip for Atmega programming; it is indeed very easy to program Atmega using Arduino UNO.
No fuses, no additional setups. What you need is Arduino UNO and another Atmega328P.
Just burn bootloader into new Atmega and than flash the hex code.
And that's all.
...[/FONT]
Not actually. Not in cases like this is.Originally posted by 6666 View PostWouldn't burning the bootloader into the atmega328 slow down the chip ?, I dont know thats why I am asking
Observe bootloader as something similar as boot sector at hard disk.
It's only there to start up the chip, so that's only minor delay which happens once after switching it on.
Completely harmless.
Yes, Arduino will make your life much easier. And once you having it; you will be tempted to try other things with it too.Originally posted by bernte_one View Postok sounds i have to try using arduino as programmer seems easier as i thought
i had no plan how to set fuses with arduino die
but if i havn´t to do that- fine Problem solved
how can i disable the Counter easy ?
It's not easy to screw the counter.
Peek&poking the addresses is the only way.
Lot of trial&errors in meantime.
But with Arduino you will be able to reprogram it easily whenever you want.
300 tries are not problem. Once in a year to reprogram it is not big problem.
But i am optimist, i still have hope that author will decide to give us code some day.
I have exactly the same problem, only the coil is 52cmOriginally posted by jladre View PostTest stage..not what i expected. Maybe coil is the problem..using my delta pulse coil with 56cm diameter and 400uH inductance..i can only detect 24cm plate at 110cm distance..too far as what this pi promise..maybe my coil not good..[ATTACH]34196[/ATTACH]
Parameters are 230mhz impuls 130 .....
I think that will be more powerful ...
you were right, the problem was reversed lf357 poor creature to another and instantly changedOriginally posted by jladre View PostI made spider wound coil 28x60cm, 350uH, 1.5 ohm and a round coil 60cm diameter.. Same result no progress... Detect 1euro at 40cm and 110cm for a 20x20cm metal plate..
It shows great depth of 1 EUR coin sees 50cm only now is a problem with the earth resistance is constantly changing
I have not yet tester to measure the inductance , but maybe a bad coil....
I lets make a 1mx1m reel and I'll see what the results will be
I want to ask, maybe it is possible to get hex at least 600 and more ,than 300 times, it would be fair to allOriginally posted by ivconic View PostSorry pluto923 but that's out of question, from pretty understandable reasons i hope.
Somebody else bypassed the counter, not me, so i can't share it , sorry.
I got it only for my personal use. Sorry again.
And of course on the very first place comes the author Hammid with protection of his own intellectual property which the hex code is.
So if i do share cracked code here or anywhere else; i would become "double thief"!
I just wanted to show how possible is to crack (bypass) the counter and nothing else.
In good hope that author will understand this and do better stuff next time, in next version.
So sorry again; no share. I don't have ethic and moral rights to do that, sorry.
