Hello, i am thinging to connect felezjoo pi with my android application via bluetooth in order to proccess and visualize values.
Can you please guide in wich pin of atmega is the output?
Thank you in advance.
Where is the pcb file?Originally posted by star View Post[ATTACH]54182[/ATTACH]pcb 83x48 m
- Likes 1
This is the version that's most often found on the net:
- Likes 1
For those who copied the project, this is the joystick board that was meant to be used on-board: LINK
You will have to desolder the last 2 pins labeled SET and RST because they are not being used on the layout.
In the final version the joystick key will be on-board without the need to buy the external joystick module.
I was going to present it at some point. It's still a work in progress.
At the moment I will make the project private and I will release the final SMD version at the forum.
For the rest of the guys that copied the project, please use it at your own discretion only.
Felezjoo PI variant with all major components on-board (LCD, joystick board).https://easyeda.com/MDfanatic/deepi-smd-metal-detector
unlimited and no counter for all
FelezJoo_PI_v3_35 (no counter).hexAttached Files
- Likes 1
Hi friends can ennyone here get nother hex file for this felezjoo. Because felezjoo of balgharia has hex file allergy
Hi Dear Amin , could you upload it here? Thx for your kind interest.
