Originally posted by ripsdevala View Post
Thank you ripsdevala,
... but I am looking for editable schematic not PCB layout
Originally posted by Altair View PostI am searching for a schematic to edit but I found only PDF ones; are there somebody who can post it, please?
hi every one i have many days trying write E fuse to FC with avrdudes but i couldnt its give me erorr ferviting idont know what i did wrong is the programe avrdudes doesnt contain E fuse FC or what should i do
Thanks for the sugestion, I think i have wrong oriented bc337, my LCR read it wrong, now it can sens coin for 25cm in strong emi area. But the sound is weeker maybe i need a bigger speaker, i use pc beep buzzer.
Tell me if im wrong, to use this md its need to ballance it every above the ground to minimalizing ground effect.
Originally posted by Geo View PostYesterday i compared the 3130 with the 357. Both have about the same depth.
I think that 3130 gave a bit better waveform than the LF357 but at soda can the LF357 detected it at 2cm more.
At coin 1 euro i did n't see any diffference.
Ivica,,,, sorry but i did n't find a LM318 for test...
GEO, could you please tell me did you try a CA3130 or CA3130A
they are different spec chips
thanks.
Frequency 180-240, delay 0, pulse width 100-140, ground 2, speed 8, integ 28- 40,..choose first the higher value on the range, if still ringing reduce the sensitivity up to 16, if still ringing reduce the pulse width, if still ringing reduce the integ to 30 below, if still ringing reduce the frequency up to 200 or below..i your board or parts have no problem with the sensitivity of 14 machine will work will..for wet and dry sand sensitivity can work up to 18.
S9 D0 F403 P110Originally posted by nae View PostWhat are the values S D F P settings?
FREQUENCY 403 (More value increase detection speed)
INT.G 18 (more value increase air deep)
GROUND 1 (more value = longer ground Ballance)
SPEED 10 (more value increase detection range and speed)
This is my setting to be work above the ground, else it will always ringing, coil is unshielded ,i was bought $8 graphite spray, and put small cooper clad with wire as graphite contact, but make it terrible with the sensitivity.
What are the values S D F P settings?Originally posted by ripsdevala View PostGuys, how you all manage to get 30cm air test for coin, the best i get is only 20cm with 23cm chance coil, 0.8mm 350uh.
Never get 1m for big object.
Above the ground, coin is about 13cm with proper setting
Geo Thanks!I tried AD8055.It works well, stable, an automatic delay of 6 us .... probably because of its high speed ..Please put AD8055 and the oscilloscope to see the result ...Perhaps a two-stage amplifier would work better, first with CA3130 and next to AD8055.Originally posted by Geo View PostYesterday i compared the 3130 with the 357. Both have about the same depth.
Cant find graphite powder here, i only have battery carbon, but not good enough, +white glue is 200k ohm/inch
, so will look it and if it is the A series will inform you.
