Originally posted by green
I tried your test, with the following results. Foil used was 0.02mm thick. An accurate 1inch square was cut and this was undetectable by the VMH3CS with the stock coil and standard settings in Normal mode. However, when folded twice and held tightly together it was detectable at 2.5inches under the coil. This figure did not change when switched to the mineralised mode (ground cancelling) which was previously balanced on a piece of Australian ironstone. If folded twice more to give 1/4inch square, the Vallon will now detect it at 3inches in Normal and GB mode.
Eric.
