  • JdaleH
    Does anyone have an ExpressPCB layout? I would appreciate an ExpressPCB file, even if incomplete. Thanks, Dale
  • rodrigo_mattia
    In using 2n7000, you can apply it ! Pls check the position of leads !
  • rodrigo_mattia
  • rodrigo_mattia
    Hi Friends,
    Im testing this configuration and
    1)to conect a led
    After c15
    --capacitor(c15)---resistor(1k)--diode(1n414--led---to ground
    2)To conect a speaker and Fhone
    .............................................|---Phone---500omhs---to ground
    .............................................|jack key
    --capacitor(c15)---resistor(100r)---(speaker 8R)----to ground
    .............................................|---100nf---to ground
  • BC547
    The LED in the film of Rodrigo is connected to the auido output.
    And yes, you can use BC547B - no idea about 2N7000.
  • popka-ru
    I understand that BC549B can be replaced with BC547B, or you can apply 2n7000 to this mosfet.?????
  • popka-ru
    Thank you. now it will work. I will prepare for the assembly.
  • popka-ru
    why does the light flash all the time, where is it connected to?
  • rodrigo_mattia
    Hi Friends, Greetings from Brazil, follow my video from Pickini V4.
  • BC547
    Also, the coupling elco on pin 12 for the audio signal is reverse polarized.
    Looks like you have an old Arionas layout - before he fixed all the initial errors.
  • BC547
    Yes, it looks OK now.
    Have a look at Arionas' layout in post #200 in this thread/
  • popka-ru
    Originally posted by F117 View Post
    The LM318 mask is upside down. The traces around it are OK.
    Pin 8 and 9 of the PIC16F1824 should be shorted.
    So?
  • BC547
  • popka-ru
    and another question, are there any errors in this print?
  • popka-ru
