2nd Chance PI
  • dantech
    No, but you can use kicad archive from my repository and then you should find bill of materials in the Kicad
  • ripsdevala
    Dantech, do you have the part list to build?
  • dantech
    v016. Small bug in the "Volume ascending" submenu repaired
  • dantech
    Have to work well with unmodified 1st ChancePI
  • Spyke
    @dantech: thanks for sharing
    Did someone test it with unmodified pcb chance1?
  • dantech
    v015 released
  • dantech
    v014 is released
  • dantech
    Special v003c version for ATmega8 only is released.
    Because lack of free time that version was not tested at all.
    In theory it should works.
    v003c has a few modifiacations (not all of course) from higher versions for ATmega328
  • dantech
    Aaaaaaa! I see. Right, the pin 2 is input and pin 3 should be ground. Inductors are placed incorrectly also. Fact, there were a few bugs in this place
    The Kicad archive is corrected now. Thanks for warning.
  • baum7154
    Thanks Wahyu,
    I see that the original 10 ohm resistors were replaced with 4.7uh chokes. Not sure that it makes any difference as the opamp current draw is so small and there are two sets of filter caps on the +UP/V+ and on the -UP/V-.
    Dan
  • Wahyu
    schematic
    Chomikuj.pl to przyjazny serwis do przechowywania i udostępniania plików. Darmowa, nieograniczona przestrzeń i mnóstwo plików do pobrania.
  • baum7154
    [QUOTE=Wahyu;222616]Hello dantech
    i see schematic NE5534 have LC DC filter, capacitor before inductor for DC filter?
    capacitor->inductor , or inductor -> capacitor
    _______________________________________________
    What schematic is this from? Looks like it is adapted from original Chance. Also Chance uses an OP37 op amp that is superior to the NE5534.
    Dan
  • eclipse
    Pin3 of the preamp must be connected to GND and yeah that LC filter doesn't seems correctly connected.
  • Wahyu
    Hello dantech
  • dantech
    Quick metal discrimination test
