GOLDSCAN 5 SCHEMATIC QUESTION
  • dbanner
    I see a multiplexer chip(HEF4053BT). This is more advanced circuitry. since the TDI is now out of production, its resale value is bound to go up? As for front end, cant make out some numbers, picture resolution not so good. i also see a 16 lead LT1114S(pin 8 and 9 N.C.)
  • Altra
    At TDI the second preamplifier is a NE5532, not a AD8055 as at GS5.
    Here is a TDI picture with a NE5532. Maybe a cheap replacement for the NE5534 and AD8055?
  • dbanner
    Thanks. I try with 47K, this is logical.
  • Altra
    I left out this section, and what about this resistor? Is this right on schematic?
    Remember this was a proto type test unit. Two 100k's in parallel to make 50k later they have used a 47k ? The amp you left out was not used on the production model.
  • Qiaozhi
    It would probably be best if you guys nominate one person to maintain the master files, and others can make suggestions by posting modified schematics and /or PCB layout. You cannot possibly all work on the database at the same time. Even with some form of revision control, only one person can check out the design at any time. Otherwise it will become a free-for-all, and anyone working on this will become frustrated.
    On a positive note ... it's good to see a number of Geotech members working together to solve a problem.
  • Idefix
    Would you post a picture of these part of the board ?
    With a 5532 , there will only have 2 resistors by OPamp, and there will be close to circuit.
  • dbanner
    In pdf
  • Geo
    Originally posted by Jose View Post
    We must assume then, that TDI has three stages in the preamplifier...
    Jose
    Yes, but i don't have the values of resistances to determine the gain....
  • dbanner
    Yes, good idea, but when trying to unzip, will the file extension be recognized(*V.0.1.zip)? I will do this from now on.
  • Idefix
    GS5 AUDIO V1.zip
    just a help : may be better to add a revision number to files, even on the zip.
    Like V1.01 V1.02 an so on. Filev1.01.zip..
    If not , once downloaded , there is only the date inside to identify..
  • Orbit
    I tried to rename extension to *.lay for sprintlayout 5, but it still doesn't work. Sprintlayout 5 does not recocognise sprintlayout 6 files.
    It's okay never mind !
  • dbanner
  • dbanner
  • dbanner
    O.K. Changed label to AD654 and corrected B-
  • Orbit
    Post#261
    The same marked ! AD8055
