GOLDSCAN 5 SCHEMATIC QUESTION
  • dbanner
    Post#261
  • eclipse
    dbanner AD8055 is AD654
  • Orbit
    Now i try to make pcb and test.
  • dbanner
  • dbanner
    Corrected. AD654, B-.
  • Orbit
    Hi dbanner ! Can you in SprintLayut 5 ?
  • Jose
    At TDI the second preamplifier is a NE5532, not a AD8055 as at GS5.
    We must assume then, that TDI has three stages in the preamplifier...
    Jose
  • dbanner
    Here is a layout for GS5 audio based on schem that was posted of TDI Audio.
  • Geo
  • Geo
    Thanks to all of you.
    I own a TDI and i need schematics only for repairing( if will needing) or for modification.
  • Jose
    Can you post the file as jpg type because i can't open them???
    Thank you.
    Hello Geo
    Thanks to Eclipse, you can see the files.
    With regard to audio, I want to clarify that it is experimental, inspired by images taken from different forums, schemes published by Miscktv, the audio of Scope CS7, in addition to essay and error.
    This version works with 12 volts, which is why it uses a negative low-drop regulator.
    In some cases, the connectors must be taken as a connection point, because they do not match with the other board.
    The purpose is to serve as a basis, to update it with the schemes published by Altra.
    Jose
  • eclipse
    If you take a closer look on both files there is a note (date which can serve as version number), and I can't edit my previous post.
  • 6666
    For those people who are planning to update the schematic can you please put a date on the schematic and a name so we know which is the latest version
    thanks.
  • eclipse
    Okay as a DipTrace preacher I should export the files but really you should try the app. It's free under NNN pin schematics (main board is too large for this).
    Goldscan 5 by Jose (main)
    Goldscan 5 by Jose (PSU & Sound)
  • Toros
    I think that the Dip trace does not allow export in jpg format. The program has its free version and you can download it whenever you want.
