GOLDSCAN 5 SCHEMATIC QUESTION
  • scs
    Patience! You will soon see my easy to make Pi discriminator schema. It works great.There is no point in discover the hot water.Click image for larger version
  • saba
    Thanks my friend, im still on timing section, i see my timings is not correct like on TDI proto, First is ok about 10us but others is not good,
    Second timing D start on 34us. this is from end of TX or end of first one C?
  • waltr
    Originally posted by saba View Post
    Hi please explain, timing on TDI proto shematic is correct?
    And A,B,C.D are correct marked or have some mistake?
    If I am looking at the same TDI proto schematic then the timing to analog switches are correct.
    The Timing is C-D-A-B with C-D being the target sample-EFE samples and A-B the GEB-GEB+EFE samples.
    There are many other errors on this schematic however. The common ones are Op-amp inputs swapped. This becomes obvious when looking at the op-amp gain resistor connections.
  • saba
  • saba
    couple of errors, now some is fixed to power and TX stage
  • dbanner
    One other thing I noticed, not all 555 chips are the same internal architechture, there have been many, many changes made to them since they first came out, also there is CMOS 555 which is used here if I am not mistaken.
  • dbanner
    The supply voltage for 555 stage is shown as -10V. The -14.4V is only used to power the TX. The 2K trimmer preset adjusts the pulse width, the freq. adjust potentiometer varies the frequency. You haven't said what value potentiometer you used. Make sure you have correct power supply voltage, then everything else should fall into place.
  • Jose
    In the TDI Pro Proto scheme, the pulse width setting is a 2K preset.
    The TX width is set to 100 uS. It could not be greater because of the TX pulses, may overlap, with the second sample of the GB channel.
    We are talking about a frequency of 3.3 Kc.
    The current depends on several factors, the voltage used, the characteristic of the coil, the frequency and the pulse width TX.
    500 mA or a little more, can be considered normal, if the parameters mentioned above are used.
    Jose
  • saba
    Sheamtic is on your post 317#
    Trimmer adjust freq. from 2.4-2.7khz, power supply 14,4V,TX pulse width is bigger and cant adjust, coil is standart 20cm. mono coil for PI detectors, 2.4om 400uh.
  • dbanner
    ok cap replaced with 22nf, now freq. is 2.7khz but pulse width is 275us. after connect coil power consumption is about 850mA.
    Well, you're in the ballpark anyway. There is trimmer there to adjust pulse width, I think. Power supply 10V. Frequency Adjust potentiometer what value did you use? According to TDI PRO PROTO schematic, TX pulse width is 100uS
    850mA , I don't know. What are youre coil parameters? Which schematic are you using?
  • kt315
    at post above i saw - 3khz and 200us pulse width.
  • saba
  • Jose
    The correct value is 22 nf, I made an error in my scheme, I apologize.
    Jose
  • saba
    I will make a correction and I will still make the measurements, I hope in the other sections that there are no mistakes
  • dbanner
    Look here original board, 22nF.
