Mosfet
Originally posted by Orbit View PostYes, but I would say so !Only with this pin in/out does the device work !
Do you mean ignore the pin labels and go by the internal drawing?
If so that is the common connections for a dual, 8-pin P-ch MOSFET.
Example:
Or do mean ignore the internal drawing and only look at the pin labels?
Is the MOSFET a P-ch?? or an N-ch??
Are you looking at it from Top or from bottom?
If in a circuit maybe the leads were bent around and it is actually installed upside-down. Some makers do that to try to keep someone from figuring out what parts they used.
