Delta Pulse
  • RS_Phil
    Originally posted by blacktaci View Post
    [QUOTE = RS_Phil; 222995] Yeni Delta Pulse modu [/ QUOTE]
    What is the schematic diagram of this pcb?
    What is the diagram of this pcb?
    If you have not try the first version of Delta Pulse either Turkish or from master KT315, just do the first version first,..so if you encounter problem there are a lot
    of here can help.
  • serban
    For the quarantine days ....
  • dbanner
    Originally posted by Brian Deese View Post
    The sample pulses I was referring to are the output from the 14538 monostables which control the 4066 gates .
    Yes, sample pulses (sample timing control pulses aka sample pulse train) are coming from the 4538's outputs. They can't be anything else.
  • Brian Deese
    The sample pulses should be rectangular pulses not square waves. As far as I can understand, the term "square wave" is not applicable for sample pulses of any kind in a P.I detector. I don't know why people use this term.
    As far as I know, they should be flat topped and rise/fall time should be minimal with no overshoot.
    The following document is a good read on the delta pulse. There are scope photos of the sample pulses included in the document.
    Thank you I will read that. The sample pulses I was referring to are the output from the 14538 monostables which control the 4066 gates, not the actual sample of the coil voltage.
  • dbanner
    The sample pulses are not perfect square waves though,the top is not flat but is pointed.
    Hi Brian.
  • kt315
    Is that your house KT315 ?
    a view from window. now we have some warming. and bad news today... first CV deseased in town.
  • Brian Deese
    I have a Delta Pulse 2. I have assembled it and I am looking for a operation description. What each stage of the circuit does,and how to verify it is working with the scope. I have checked the Tx and I see the Frequency is adjusted by PR1,and the Tx width is adjusted by the Noise pot. Frequency adjusts from 110-140 hz. The Tx width adjusts from 60uS to 300uS. I have also probed P2,and P3 and I see my sample pulse main delay is adjusted by Signal pot from 18uS to 68uS. The secondary sample pulse delay is adjusted by the Sens pot. The pulses are timed correctly and do not overlap at max delay of main sample,and min delay of second sample. The sample pulses are not perfect square waves though,the top is not flat but is pointed. I do not have either of the switches connected. I do not know what type of switch J3 is or which lead is common. I have the schematic,screen print,trace layout,and BOM. I have not seen a operational description though. I will start reading through 150 pages of this thread,in the meanwhile.
  • 6666
    窗外的雪
    snow outside the window https://www.youtube.com/watch?v=dHDJvYhFLjI
    reveal a lot of information, too.
  • 6666
    Originally posted by gaby_sult View Post
    Here is what I did.
    If you follow the scheme and the values will work from the first.
    [ATTACH]49824[/ATTACH]
    Thanks for marking the power connections to the 4066
  • gaby_sult
    Here is what I did.
    Delta Puls.rar
  • blacktaci
    [QUOTE = RS_Phil; 222995] New mode of Delta Pulse [/ QUOTE]
    Thank you kt315
    What is the schematics diagram?
  • kt315
    a folder with all/full files you can load in this link https://dfiles.ru/files/yi7t9r92k?redirect
    files as oldest, so new, also keeping files on turkish board.
  • blacktaci
  • kt315
    Originally posted by jinbiao View Post
    This photo can reveal a lot of information[ATTACH]49664[/ATTACH]
    窗外的雪
  • liudengyuan
    Not speak English, please roll out the forum
