Bulgarian 'PULSE STAR' (... close to Legendary one)
  • Pulse Star G
    Hello Georgi, Thanx for verry much for your great work and for sharing your knowledge with us, i have read few times all your posts, i will start this project and i hope will finish it with success.I will post my results when i am trough.
    And hello From Romania
    Marius
    • Originally posted by steaua581 View Post
      Marius
      Bravo Marius, this is right approach.
        Marius
        Salut Marius !
        Daca nu gasesti ne5534(5532) si vu-metru cu zero pe mijloc nu are sens sa te apuci de constructia ps-g ; eu personal am construit-o cu lf357 , functioneaza dar momentan are performante la detectia in adancime mai slabe ca delta-pulse .
        Thanks Georgi for your project !
        Greetings from Romania !
        • salut steaua , dali aj pcb kare je bun jou am fakut dila molah pcb ama nusint sigurat ka jeste kum trebuje dar ojavja tu bun pcb sema alu gjorge jeste misapare korektna de puls star g.
          • dekut sa spun ka gandesk la sema alu gjorge ce a dato din nou ce je fara bd si bc oscilatoru gandjesk sema a noau 9 ma rog sa ma izvinjesti ce nu bas skriu kum trebuje jeu stiu rumaneste sa vorbesk ama nu stiu sa skriu bas kum trebuje.
            • Originally posted by serban View Post
              Salut Marius !
              Hi serban! 5532 (dual ampl.) Is not equivalent na 5534! Use LF357.OP27 (no OP37). Mikkroampermetar be binding, it is basic discrimination. indicator! LED FER. LED NON FERROS and have little sensitivity
              Test should be done not in the workshop, only real test of the field (forest), the scheme is very sensitive. Coil 20 centimeters to 30 centimeters!
              • gemajlu al mjeu je [email protected]
                • mailu al mjeu je [email protected]
                  • PS-G
                    SERBAN, please write what the results obtained, the sensitivity of the sound channel (target) and discriminator, what sensitivity are you working (ferros and non ferros).
                    G.L!
                    • Originally posted by georgi.g.zhelev View Post
                      A test should be done not in an workshop, the real test may be done only at a field and in a forest, the schematic is very sensitive. take the coil from 20 to 30 centimeters of diameter!
                      • Komsu Georgi ,
                        excuse me , but I could not get same results
                        all results were positive after subtracting second sample.
                        okantex
                          Hi. You make the scheme or use simolator program? On simolator will hardly get a real rezoltati. Make the scheme a PCB, only then you will understand how it works
                          • My schematic is different. I use PIC .
                            just wanted to use your timinng .
                            I got samples in 3us .I got first from 100us. and second from 250us.
                            first is always bigger than second sample.
                            • PS-G
                              TEST: DELAY second sampler 150mks around! (not 250mks)
                              G.L.!
                              • first sample at 100mks
                                second at 150mks
                                ok . I will try soon
