Felezjoo Pi- adjusting automatic delay, A,B and C values to perfection!!
Thank you very much Nightryder for your advice and for sharing your files.
I've built Felezjoo before and haven't figured out the ABC numbers. Now I will follow your advice and see what happens.
I would like to know what version of the HEX file you have used and if it is not too much trouble, could you share it?
Now that I actually have a proper functioning Felezjoo, I'm getting familiar with its settings & potentialities. I think the speed setting is more like "gain" in analog detectors. If I adjust it (in harmony) with the sensitivity setting, I get an impressive depth!
Speed & Sensitivity settings complement each other for sure.
There is still much to be desired from FelezJoo and the experiments will continue there is a glass and there is water, but who will drink water how and whether with a glass or without a glass is his business
I prefer Whiskey, Irish.
As W. C. Fields said "Don't drink water, fish f**k in it".
Fellow Nightryder, make a video clip so we can see in depth what the results are. Thank you.
Yes, the best way to publish a video is with YouTube, if you don't have an account, make one, it's easy, then you log in to the YouTube account with your email and password, after you upload the video and it's approved, it's also quick and easy to play the video, copy the address of the clip and post it as a message here so with this address we will all see your settings and results with Felezjoo
Algan,
Let me get this strait. So you want me to go through the troubles and make a new YouTube channel dedicated just to convince you to fix a problem that it is actually yours not mine? like if you have any thing to loose?, like if I have a personal benefit in all of this? Or like if you have not already seen what a good Felezjoo's performance looks like on YouTube?
Well, I do have a YouTube account. It is private and I intend to keep it that way. And I'm not about to make new email and account just for you to believe or for your satisfaction. I'm also not here to convince you personally to take my advice. You can absolutely leave it !
When you mentioned your challenge with this project, I truly tried to find a solution for you " assuming you were honest and did have an issue" and I specifically asked you for measurements of certain things. After a long time, although you were online all the time, you came back only with ABC values and ignored everything else !! I mean it did not seem to me you had a challenge in the first place!
I can not believe I had the headache of converting and cropping and resizing the video last night. I absolutely regret it now!!
You could have waited to see members' reaction to my advice after some time and then decide for yourself. But instead, you are demanding things to be just for your personal preference ! or maybe waiting for me to make a mistake to spread that negativity of yours which by the way I clearly can see it.
Is that what you really do with people here? Don't you have something better to do?
Maybe it is time for you to realize that this topic is not meant for you personally. Ignore it and move on! This is a lot more easier than making a new YouTube channel!
