bad pi curve
    Hello
    Now I have a new problem. The curve of the second preamp stage does look false. The following picturesy are oscillograms of my curves with different amplification of my scope. the yellow curve is from the first preamp stage and the blue from the second stage:Click image for larger version
ID:	426372Click image for larger version
ID:	426371Click image for larger version
    On the middle wire of R6 i get a voltage from about -1.5 to +1.5 volt. in the video you can see waht hapens if turn R6 from his minimum to his maximum:
    When I replace the op the mistake does not apear. Using other coils doesnt helps too. I testet the second pramp stage with some test signals the results are in the following pictures:​Click image for larger version
ID:	426376Click image for larger version
ID:	426375Click image for larger version
    I rebuild the circuit with the same components in a breadboard and get the same result. there i testet the first preamp stage the results are in this picture:
    In the next picture is the row signal behint the diodes
    by Levin​
      what could be the problem here
