Originally posted by kt315
Sniffer XR-71 help
A photo of old Delta Pulses that I found on an external hard drive.Originally posted by aft_72005 View PostHi Jafar.
I built the Delta Pulse years ago... it worked well.
If I can find the circuit, which is in the storage room at home, I will turn it on and upload pictures of the waveforms of its various points here.
from year 2009
Where did you connect the oscilloscope probe’s GND in this measurement? When I connect the GND clip to the circuit’s virtual ground, nothing appears on the screen — but when I don’t connect the oscilloscope’s ground probe, a waveform is visible.Originally posted by aft_72005 View Post
preamp pin 6 opamp
Hello my friend, thank you for taking the time to send it. If it’s not a bother, I’d like to stay in touch with you more. If you have any way of contact available — such as email or Telegram — I’d appreciate it.Originally posted by aft_72005 View PostHi Jafar.
Connect the oscilloscope ground to the virtual ground. I did the same thing.Originally posted by Jafar View Post
pin1 TL062
pin1 TL062
Yes, via the Telegram app.Originally posted by Jafar View Post
I am also happy to answer any questions you might have here, to the best of my knowledge.
Thank you for your kindness. I truly appreciate your help. @amirali_sa_13 — this is my Telegram ID. I’d be happy if you send a message; I’ll be waiting for you.Originally posted by aft_72005 View Post
