Felezjoo with the ability to discriminate.
I don't like that design, and in fact, the design I'm using is specifically for testing because it's well-designed and can be programmed directly from the board. It's worked for me, and to be clear, I didn't design it, but I like it, so I'm using it. I don't like your design, and I hope to use it during the migration from the ATmega2560.
Also, I don't know if you noticed what extra features it has compared to other designs.
That's why I said I don't have that many tools, and I don't have that much money either. I've worked in agriculture, as a bricklayer, and other jobs, but now I'm a mechanic. I'm not a technician, but I've never stopped studying, and if something interests me, I study it. That's why I've learned about electronics, not enough to say I'm a technician, but I've always thought that you should never stop learning.
And as I said, since I saw the FELEZJOO Rev A-2 design (updated October 8, 2021), I liked it, and that's why it's the one I'm using, but it has some other differences.Attached Files
- Likes 1
I wonder if the Falejoo software you updated is also up to date?Originally posted by sabios View PostThat's why I said I don't have that many tools, and I don't have that much money either. I've worked in agriculture, as a bricklayer, and other jobs, but now I'm a mechanic. I'm not a technician, but I've never stopped studying, and if something interests me, I study it. That's why I've learned about electronics, not enough to say I'm a technician, but I've always thought that you should never stop learning.
This is precisely a version designed to be used exclusively with this board, as these changes mean that only this version is working properly. It took me some time to achieve the desired results, and it's still in the testing phase, as it seems some further adjustments are needed to stabilize its operation.
Through testing, I've realized that this version makes discrimination more reliable and has fewer errors. I even used it in a garbage dump, and using this version is more dependable because there are no false positives. The downside is that, since I don't have any high-quality gold and silver to test with, I can't be certain of this version's capabilities.
