BI-PI Pulse
    Colleague haylaz0036, where are you from? I can sell you Carl​'s board and I will program it for you and sell it with the chip, no problem.
      I am Turkey
        If it uses the same source code as the ITMD3 circuit, then all the code is in C and you can download it from the ITMD3 forum. Then you can port it to whatever processor you want. If you don't know how, then this is an excellent opportunity to learn.
        Hello Karl NC
        Which chips can we port the code to?
        PIC16F18426
          Originally posted by haylaz0036 View Post
          I am Turkey
          No problem, I'm from Bulgaria, I can send you the Carl​'s​​ board and the chip programmed , but the video shows Eduardo's board, I don't have that variant.
            Originally posted by pechkata View Post
            Hello Karl NC
            PIC16F18426
            Practically any PIC you want, as long as it has enough pins. Peripheral register may vary a little bit, and if you use a lower speed device it will affect timing resolution.
