How to Program an Arduino Based Metal Detector
  • How to Program an Arduino Based Metal Detector
    Interesting article How to Program an Arduino Based Metal Detector
    https://www.instructables.com/id/How...etal-Detector/
    It's better to use one PWM pin (OCR1A) for driving the MOSFET without servicing any interrupts.
    Pages and table references for Atmega328P datasheet at https://www.sparkfun.com/datasheets/.../ATMega328.pdf
    PHP Code:
    /*  Pages and table references for Atmega328P datasheet at    https://www.sparkfun.com/datasheets/Components/SMD/ATMega328.pdf
        Clock assumed to be 16MHz.                          */
    #define F_CPU 1600000L
    uint sampleDelay 16 10// 10 us sample delay;
    void init(void) {
    /* Timer 1 in Fast PWM mode 14 (page 136, Table 13-4)  */
    TCCR1B |= (<<  WGM13) | (<< WGM12);
    TCCR1A |= (<< WGM11);
    /*  Compare output mode in Fast PWM:
          set OC1A at BOTTOM (0 count),
          reset OC1A on compare match. page 135, Table 13-2     */
    TCCR1A |= (<< COM1A1);
    /* Compare match registers for  timer 1  */
    OCR1A =  4000;               // 250us pulse
    OCR1B =  4000 sampleDelay// 16 = 1us
      /* The TOP value of timer 1 for Fast PWM 14 is set by the ICR1 register (page 139) */
    ICR1 16000// 1ms period, 1000 Hz pulse rate.
      /* ADC configured to sample on timer 1 compare match B
         and generate interrupts on conversion complete */
    ADCSRB |=  (<< ADTS2) | (<< ADTS0);  // ADC trigger source: compare match B in timer 1
    ADCSRA |=  (<< ADATE) | (<<  ADEN) |  (<< ADIE); // Autotrigger, enable interrupt, enable ADC
    ADCSRA |=  (<< ADPS2) | (<< ADPS1) |  (<< ADPS0);  // Prescaler 1/128; 125 KHz
      /* Start pulsing */
    TCCR1B |= (<< CS10); // start counter at maximum clock speed
    int main (void) {
    cli();
    init();
    sei();
      while (
    1){
    // do your thing
    ISR(ADC_vect){
    // do your thing
      Excellent article!
        That's great! This article is very useful. Thank you
          I built one just for understanding purposes and it's working: https://www.youtube.com/watch?v=LwxB16ynQGs
          Thanks!
