ELYAPIMI PLL DEDECTOR
  • nakky
    IC 3 filter (2).zip
    Grt Nakky
  • porkluvr
    Originally posted by cnckecgo View Post
    You gotta draw the pcb of this schema eduardo
    Why won't you post the schematic that goes along with your PCB diagram? I mean, you started this thread with a PCB and included no schematic. Wha?
  • dekoratör
    nakky Have you pcb file can be printable
    can you publish please..
  • galaksi
    cnckecgo, what schematic did you use.
    In your PCB I see 9x (R) 39K.
    In schematic Eduardo and Ivconic I see 3x (R) 39K.???
    Grt Nakky
    3x (R) 39K , Add CD4007 pin.2-9 between the NE5532 pin.2 , NE5532 pin.6, NE5534 pin.2
  • nakky
    Grt Nakky
  • cnckecgo
    Dear Eduardo I am waiting for help about modification of elyapımı to get better performance.Pls help to modification
  • cnckecgo
  • cnckecgo
    bravoo nakky:
    Eduardo , waiting for your interest about the schematic with this subject for revealing a good project
    this detector is very stable.not giving false signal,working good at minerilized soil and very sensitive for tiny parts and money
    how can get better performance by changing design and some parts ?
  • nakky
ID:	334445Enjoy if you like it.
    Check it before you make it.
    I have check it but I am not perfect.
    Grt Nakky
  • 6666
    Thanks eduardo1979
  • cnckecgo
  • eduardo1979
    eduardo1979
    In your schematic I see that you are useing a simple LM7809 and two 10K resistors to form a virtual split power supply.
    What is the regulation like with such a simple power circuit ?
    This voltage divider works great and no need to use an operational amplifier. I've checked all my projects and works great. The resistors have to have a tolerance of 1%.
  • 6666
    eduardo1979
  • eduardo1979
    Yes, with some modifications.
  • galaksi
    Originally posted by eduardo1979 View Post
    Here is mine. A month ago I've drawn and now I will test it. Hope it works well. Greetings.
    eduardo1979 Is this your design?
