    i made the detector (modified version by Tepco) 3rd post in this topic
    The coils are not finished yet , i made TX ~ 45 turns of wire 0.4-0.5mm c1 = 0.3 microfarads //RX ~ 200 turns of wire 0.15-0.22 mm C0 = 0.022 microfarads... just to shealld properly
    The problem is: when i connect the power source , after 20-30sec the LCD screen start to light but nothing on it to read just blue screen light...And on the speaker constant beep sound (like vibration from telephone) I try to reprogram the Atmega8 chip few times the problem continues... All parts are like on the modified project by Tepco,instead of IC - MCP602 i use (MCP6021) so is possible that it is the problem, so is there any replacement for this IC??? Any suggestions help ??? thanks friends
    • anyone know if the software is free? ... you can change the menu and LCD and put it in Spanish?
      • is it possbile to use another lcd then the winstar, it is not easy to get and not so cheap as a
        1602 lcd hd44780
        maybe the Software can be rewritten with a hd44780 library
        or have anyone tested and winstar and hd44780 is equal for this Project?
        • Hi, MCP receiver. Atmega8 is programmed. Trouble, Atmega8 fuse, next, LCD screen> Atmega8.
            1602 lcd hd44780
            hd44780 is suitable.
            • would it be possible that someone you translate the firmware in French? I mean the interface on the screen. . thanks
              • A new firmware "Gain" for "Mole2". Try not regret it! )
                MOLE - GAIN on 07/08/2015 6-17kGts frequencies. Added: Hardware input gain mode Gain (* 1, * 2, * 4 * ) Amplitude clipping "black" signals SX X = 0-9. Profiles are now are located in the factory setting "Factory Settings" mode "Profil" edit the profile name with the "0". The new profile takes effect when you restart the device. Entering the factory settings "+" and "-" at power up. Added a new filter F2 (deep for simple and medium soils). To go to the firmware will have to edit modes "Zero_Adc", "Battery", "Ferrite". Recommended settings for standard coils: frequency ~ 10 kHz, S22F2, Gain = * 2.0 (three stripes). Power = 80-120mA, HPF = 4. NEW
                • Hello friends! Here's a video about the work of the latest firmware.
                  • More videos ...
                    • Hi
                      I'm in the middle of buildin the DIP version of this board. What capacitors are recommended for the build ?
                      ceramic disc ones ok for the majority of them? And for TX metalized polystyrene film?
                      I'm interested in using a large coil for this MD. (Over 50 cm) can anybody point me in the right direction for this ?
                      Kind regards.
                      Matt
                      • KPOT2 SMD version
                        Hi everyone.
                        I'm building the SMD version of KPOT2 with ATXMEGA32. I have two questions :
                        1: What do the 12th and 13th pins of the ATXMEGA32 do ? They are cabled on my layout version but are not cabled on the schematic... See Picture
                        2: How do you program ATXMEGA32 with USBASP ? I've seen a schematic of the wiring, could someone coment this ?
                        I've already etch the PCB, not so easy to make SMD board
                        Thanks a lot
                        • I'll tell you.
                          1) With these two contacts you can turn the Mole-2 in Mole-3.
                          2) Look here. http://radiodom.org/index/usb_progra...klon_quot/0-16
                          • Hi,
                            I have the ATMEL ICE device.
                            I can program the XMEGA for you with the latest firmware if you like.
                            I'm in france, you can send by mail and for few euros, i send it back to you.
                            • Hi retooyep,can you tell me your price for programm xmega,i'm in france too,regards.
                              • I only have AWG24 for TX and AWG30 for RX. Is it ok for this project ?
