TM800
  • #46
    Gracias Ismo
    favor envíeme los archivos. Lo intentaré.
    Gracias
    Saludos [email protected]
    • #47
      Originally posted by Ism View Post
      I put the posted schematic into DipTrace free version. So it took two boards double sided because of DT freeware limits. If you want my files, you can PM me your email and I will send m schematic and PCB files.
      If you get DipTrace, you can verify my work and print PCB trace for making your own boards. You should be able to merge them for etchng PCB.
      BTW, I only did the main board, not the antenna circuit boards because I am upgrading my TM600. I don't plan to go that deep into tearing it apart.
      Who are the differences between TM800 and TM600???
      • #48
        As far as I can tell, just the null pots are changed to trim pots (removed from user control). Possibly some resistor values changed.
        I haven't gone through the board component by component, but everything I have compared so far to TM800 schematic is identical to TM600.
        Not sure if TM800 uses 0-ohm resistors for jumper like TM600. They are not shown in schematic.
        • #49
          Ism
          I would like a photo of the other side pleases
          • #50
ID:	339381Click image for larger version
ID:	339382Click image for larger version
ID:	339387Click image for larger version
ID:	339383Click image for larger version
ID:	339384Click image for larger version
ID:	339385Click image for larger version
            • #51
              • #52
                Thanks kt315
                • #53
                  Thanks...
                  • #54
                    Here is TM600
                    • #55
                      This is schematic for 3D. It is similar to the patent invention of TF900. Schematic sheet for 3D above schematic for TM800. !!!
                      • #56
                        i know this is an old thread now, but if anyone in the uk has a Whites TM 800
                        i have an instruction manual that they are welcome to have. i had a one some years back and it came with two manuals. so i give one with the machine and the other one just got put away in a draw.....
                        • #57
                          veltex demonstrates his new board TM-808's copy... smt & dip ver... i see those his pics in russian forum.
                          [ATTACH]28357[/ATTACH]
                          [ATTACH]28358[/ATTACH]
                          Hi KT315
                          are you have this files ?
                          • #58
                            veltex had gone. i have not the files. you can ask the files from another guy, his nick SLBAST
                            Просмотр форума - White's TM-808 • Схемы металлоискателей MD4U •​​
                            • #59
                              Thank you .
