two box
  • pito
    what you have on Tx coil ?
  • kece hon
Name:	quartz new  (4).jpg
ID:	452626 Click image for larger version
Name:	Revised_T-R_sch workiiiiing.gif
    Out of curiosity, I made a simplified version as in post #70, it works well, the cola can is detected from 80 cm, the only thing missing is ground balance, I am thinking to adopt it from other schemes, any sugestions welcome.
    a little help please Mr PITO
    i followed the instruction to build tr locator / 2 box
    i used this latest know working schematics
    instead of transistors TIP31C TIP32C i used TIP41C TIP42C which are a bit robust
    i used 16 mhz quarts which gives me 3.3 khz, i did try 32mhz the obtained coil frequency was about 5 khz= 4891 KHZ
    last quartz i put gave me the exact frequency as mentioned in the project =2048hz
    both my coils TX and RX when measured using LRC meter gives 7.00 mh
    TX= wire diameter is thicker 0.8 mm and coil resistance is 13 ohm
    RX= wire diameter is 0.6 mm and coil resistance is 5 ohm
    when calibrating ; i put the coils facing each other , beyond 30 cm distance there is no recepetion at all on the RX coil
    the obtained results at 30cm on the scope are shown in the picture
    Yellow is TX
    Blue is reception RX
    **problems**
    i need more distance than 30 cm ( the advertised distance for two box is greater than 2 meters for big objects)
    there is no significant audio change on the headset whenever i put a big object between the two coils or whenever moving them inward or outward
    --Question--
    can you help me what is it that iam doing wrong ?? Thanks in advance​
  • kece hon
ID:	452628 Click image for larger version
    Originally posted by berreizeta View Post
    I'm on it, I need to finish the coils...
    Yellow is TX
    **problems**
    --Question--
  • kece hon
    Hi Carl, Hi Forum,
    the discussion about "two-box" detector is reopened​... My T/R Locator PCB's for testing have arrived today.
    Yellow is TX
    **problems**
    --Question--
  • kece hon
  • pito
  • kt315
    1200-1500V pulse and 10-20A in coil. Delta Pulse ))) no wish to answer here more... ended matter for me.
  • pito
    simplest two-box .
    It is not simplest yet, with TC4422 I have 200 Vpp on Tx compared to 180 Vpp in original 4 transistors design,
    on the way 22cm Tx coil with the same EMF strength emission.
    Отправлено: 30.05.05 08:57. Заголовок: Re:
    А зачем в схеме предусмотрены отводы от счетчика?
    Что-то 120 вольт достичь пока не удается.
    Профиль Цитата Ответить
    IRF840
    постоянный участник
    ссылка на сообщение Отправлено: 31.05.05 06:09. Заголовок: Re:
    Раскачалось аж до 180 вольт.
  • kt315
    I found the answer.
    переключатель на плюс - прибор индицирует высокую минерализацию ( все металлы ),
    на минус - низкую минерализацию ( пустоты )
    it is just experimental device in try to make/get simplest two-box one based on Whites VLF Classic circuit.
    this switch is supposed to check in real field conditions. nothing more.
  • pito
    I found the answer.
  • pito
    What for there is switch S1 ?
    It is turning upside down the graph and what is benefit of that ?
    Click image for larger version  Name:	am2.png Views:	0 Size:	18.1 KB ID:	417158​
  • pustareka
    Перевод с английского, немецкого, французского, испанского, польского, турецкого и других языков на русский и обратно. Возможность переводить отдельные слова и фразы, а также целые тексты, фотографии, документы и веб-страницы.
    Simple Deep-T/R Locator ver1.0
    This metal detector is designed to search for LARGE objects made of non-ferrous and ferrous metals. The scheme does not provide compensation for the influence of the earth, so you can search only on poorly mineralized soils. Sensitivity to small objects such as shell casings, nails and small fragments is sharply reduced. It is possible to search for voids and inhomogeneities in the soil by the difference in soil conductivity.
    The maximum depth of detection obtained in practice :
    Sheet of roofing iron 50x150cm - 3m (by air)
    Passenger car............................... - 4m (by air)
    The detector operates in dynamic mode and does not require manual zero setting. The operating frequency is 2 kHz. The amplitude of the voltage on the transmitting coil is 120 volts. Coils with a diameter of 38 cm of 150 turns of copper wire in enamel insulation with a section of 0.4 mm. Both coils are shielded with foil, a small area of 0.5-1cm is left free from the foil (to prevent the formation of a closed loop).
    Diagram of T/R Locator ver1.0 in GIF format............................................ .... GIF 26KB
    Printed circuit board T/R Locator ver1.0 in Sprint-Layout 3.0 format.......... RAR 27KB
    Design features can be viewed HERE
    The finds made with the help of this metal detector can be viewed HERE​
  • pito
    More simple, L -Tx can be reduced to 30 cm and 180 turns, L- Rx 20cm and 200 turns.
    Originally posted by rajesh View Post
    Click image for larger version  Name:	t:r locator .png Views:	0 Size:	67.8 KB ID:	416889 ​
  • bernte_one
    Hi Carl, Hi Forum,
    much succes, hope for a short testing video
  • ivconic
    Hi Carl, Hi Forum,
    Once you finish it; please inform us about your impressions.
    Also would be nice to record short video demonstration and put on Youtube.
