Originally posted by Altair
Aquasound
was looking over the schematic and the picture of the board, i would imagine some of the components have been updated ?
This looks like a Polystyrene cap thats polarised , in the schematic has it been substituted with a film cap ?
then noticed the cap the seems to be between resistor 48 and 56 ?
and then cap 19 seems to be extra compared to what was on the board ?
Originally posted by jasonNZ View Postwas looking over the schematic and the picture of the board, i would imagine some of the components have been updated ?
[ATTACH]50270[/ATTACH]
[ATTACH]50271[/ATTACH]
jasonNZ,
the cap at your image: Screen Shot 2020-05-16 at 8.10.17 PM.png is not polarized; it's a Polystyrene one but, for the circuit that is, I believe it could be replaced with polyester one.
The cap at your image: Screen Shot 2020-05-16 at 8.09.45 PM.jpg should only modify the envelope of sound signal; it is not important for me and it not part of original schematic infact it was added later on PCB.
Important are the 30pf, 100pf and 470pf capacitors that should be silver mica or similar.
Originally posted by dom44 View Posthows is this for size very compact 75mm x 57mm haven't checked it yet and not built yet
[ATTACH]50307[/ATTACH]
dom44,
it's look well, great work!
I am busy with some minor modification to the original design in order to suite my requirements. Keep in touch!
Originally posted by dom44 View PostI was wondering Altair do you have your last Kicad schematic you posted in another format such as PDF i can't get Kicad to work on my computer at all thanks
Here the last revision I made:Attached Files
I just did an experiment with a transmitter coil I used 20 turns 5 turns center tap 5 turns 20 turns and got about 90 volts sign wave on the scope but unstable the moment you connect the earth stops oscillating still playing with it but interesting results definitely has a transformer action on the coil. i was using the 5 turn wingdings and center tap but have to play with the resonant capacitor was oscillating at about 49khz to high.
Originally posted by dom44 View PostI just did an experiment with a transmitter coil I used 20 turns 5 turns center tap 5 turns 20 turns and got about 90 volts sign wave on the scope but unstable the moment you connect the earth stops oscillating still playing with it but interesting results definitely has a transformer action on the coil. i was using the 5 turn wingdings and center tap but have to play with the resonant capacitor was oscillating at about 49khz to high.
dom44,
oscillation must be stable. Check the direction of coil connections, you must have the situation described at my post #54.
Let me make a educated guess. There was an engineer, working at Whites Electronics, back when George Payne made the Whites Supreme V model, the one in 1975, which did not have the discrimination circuit in it, which came out in 1976. It also used the older Whites coil. Now this engineer looked it over, and as he had the ORIGINAL schematics at Whites, he decided to remove the VLF, and make it a TR machine, and took it to the white sands beach of Florida. Then he kicked into extra voltage obtained in some neat way. And viola it goes 18" to 20" deep, and since there is no black sands, it finds every doggone thing... Let me go further. Later on, Whites would come out with a new coil. Then they did some changes in the circuit, to bring in the new coil. Now when other people sent in their detectors, to update them, as Ken White liked to do, more changes were made. So the Supreme V was far from the 1975 model...Then Jerry looked at it, and decided to make his Nautilus similiar, but not exactly the same kind of detector as the Supreme V. You know, engineers have said and said other times, that a detector will go deeper without the VLF, IF there is NO BLACK SANDS to content with.
Melbeta
Interesting story. I don't know how things are gone but for sure there is a sort of intriguing aura about this detector. I was working about state of the art protopype when Aquasound pass under my eye and catch me with him. Advance tecnique project I am working on can wait, now I want to do a try to this dinosaur schematic and see what happen with it!
