do your home work hard http://ipic.su/img/img7/fs/P3173294.1542657539.jpg
Tesoro Compadre Schematic PCB Rev 4.1.1
I removed and tested C2 and C24 again. Apparently I made a mistake when I entered the data to the schematic. I had not swapped them on the PCB as they were removed one at a time. I entered the wrong data on the schematic. It is corrected now and I have redrawn the schematic to make it more pleasing to the eye in certain areas.
Revison 5
MercAttached Files
The Compadre can be ordered with either the white 5.75" concentric or the brown 8" concentric. The one I have has the brown 8" concentric. Specs are listed in the forum. It is the same as other 5-pin Tesoro coils. I don't know the number of turns of wire and such. I have posted a question in the Coil area of the forum because I'm not sure that the white and brown Tesoro 5-pin coils are the same specifications.
Merc
guys
i ask you again to learn to use a light. simply try do perfect pics. no something secret from me, i am also just beginner.
http://www.geotech1.com/forums/showt...here-share-out
you must not be pained on me. i want just to lift up this forum on new level.
my collection of files. find a folder COMPADRE. open. find up a folder HR PICS. you see HR pics of the board. http://depositfiles.com/files/s6obi13mk
please be good enough to send me YOUR pics in HR (HR is 5-10MB size pic. not 290kb. not 360kb. not 1mb. FEEL THAT AND GRASP THAT).
again thanks to sender of those pics to me
