I was on an obscure forum in metal detecting when I came across this design I have just built it after redesigning the PCB the image is not very clear but it worked first go and is an easy detector to build
I have not tested it yet in the field, I am building it into a small hand held detector for checking small patches for nuggets or to search up walls.
My search coil is only 100mm diameter but shows good sensitivity I used an ne5534 for the coil amp, and a tl074.
