Blagoevgradka Grozhdanka Grozdanka detector
You are so white like never been under the sun!
Ha, ha, ha!
Local saying is "cheese".
So you wanna fly?
I have better and cheaper idea for flying;
obtain some old second hand Claymore, sit on it and fire it up!
You'll fly better than ever!
I used to paraglide.. .once i was under 120kg weight...
Good old times.
Ah yes, Black sea! I missed that.Originally posted by kt315 View Postyou do not see the main thing. I am IN BULGARIA on this photo LOL! LOOK ON THE FLAG.
Never been there but heard from many people from here that it is very nice there.
When (if) this covid stops, maybe i will go there for a holiday.
Also is very nice to visit Turkey. Been once in Istanbul and was delighted.
That's the place where i could live happy, my kind of the city.
Also Turkish shoreline and seaside is splendid too.
Very first post and he put his foot in it. That has to be a record.Originally posted by Qiaozhi View PostThat's not a very polite reply for your first post.
and be warned!
Oh, I see. Well then, that make him a double-record holder. Suffering from foot-in-mouth disease for so long can't be easy. Good job.Originally posted by Skippy View PostDB : My hunch is he has many posts on here, going back over a decade.
Having a little fun today. Little humor, you know.
This is my circuit . This circuit is very sens. end i thing is the best of the best. The TX coil make 160volt. Drill ground like chise.
Circuit is very good but not easy to adjust. Nexus is similar circuit . You can't compare this metal detector with another . This metal detector see coin on 40cm and more without any problem this is 160-200v on transmitter.
Originally posted by notron View PostThis is my circuit . This circuit is very sens. end i thing is the best of the best. The TX coil make 160volt. Drill ground like chise.
Are you referring to post number one in thread ?
I will explain briefly what this is about.
How does the scheme work? Normally the detectors work on phase shift, but here we have a natural amplification of this shift. The generator operates with a voltage higher than 150 volts. Then the effect manifests itself. The circuit became very sensitive and this required a change in the generator. In fact, this is not the full scheme. I changed the generator later because it was affected by temperature. I used a fisher generator. There are no capacitors in it.
