Building Wolf Treasure [Tesoro Lobo]
I can't get the GB to work. It could probably be because of the inductances of the coils.
Could you publish the scheme on which you are basing to be able to compare with mine?Originally posted by dom44 View Posti set mine up for exactly 20khz on the transmit coil so will set the receive coil for 20.6khz i wound my own coils so was easy, I have 1.43mh on the Tx and 9.68mh on the Rx and i have 47n cap on Tx
I am starting with 10n on C7 as i said i have not finished with the final setup but so far has exhalant sensitivity with an un tuned receive coil. there is an LT spice simulation some one posted here a few years back on the lobo front end so you can play with part values.
Hello dom44.Originally posted by dom44 View PostI am working on this detector my self still at the setting up stage works great so far, I need to try with the resonant receive coil with 600hz spacing between transmit and receive coil for correct phasing.
Are you running it at 17500Hz and 18100Hz?
What capacitor do you use in C7?
Hello friends I am wondering why leave this 600Hz spacing between TX and RX? Why can't they be at the same frequency?
i think connections of those resistors are mistake.Attached Files
Dear Ruben,Originally posted by Ruben2000 View PostThanks for the link op04 !!
I had read it before, I don't know if Max was able to get Lobo to work properly.
There are various Lobo schematics all over the web, but so far I haven't seen anyone posting all the correct information about Lobo.
My point on that link is Mr.Tchoci progress, he reveals his made with different coil and components also PCB error correction. There also Legaucho work on lobo with working PCB of began this page
Hi KT,Originally posted by kt315 View Posthow i see this sch... you have to get CLEAR symmetric signal on output of 555... to get then sinusoidal voltage
on the coil without a distortion and harmonics...
we call sometimes this signal "meander"... in last redaction, TROY SHADOW X5 i mean,
the author input a trigger after 555... it gives sure clear meander.
try to tune now...
You mean there must be a 50% high and 50% low signal at the output of the 555 and no interference?
try to tune now...
Will the waveforms be okay?Attached Files
