what's this ?
  • what's this ?
    hello, could someone tell me what this detector is and give me the diagram and the data
    thank you
    Looks like Polones with VCO
      It's missing a small PCB.
        pi polones with disc, can you find better pictures from layout or pcb file?
          https://youtu.be/Kqm4vVf8FEs
          video about it
            Its video claims to have the voice of a treasure hunter. it has ground balance
              I don't think so.
                Yes, he said, it has ground balance and balanced the soil.
                  The video showed incredible amounts of ground noise.
                    for modification with ground balance you should look for moroccan version of pi polones
                    https://simplemetaldetector.com/puls...ese_africa_v4/
                      This page is infected with a virus! It also quickly switches to a support message. Better publish the materials here.
                        When the page opens, press ESC several times
                          It does not help. But I still managed to trick this page by saving the link on the desktop and then opening it from there.
                          Here is the archive I managed to download after that!
                          Can anyone explain why two single operational amplifiers are replaced by a 4x operational amplifier. I don't understand.
                          In my opinion, the board is made rough. The ZONE function is not used. Instead, the tracks are thickened by stacking several next to each other or on top of each other.
                          I allowed myself to make a small edit to the board without changing the links on it. You can also make changes if you don't like something.
                            They modified many old PI PCB and they try to improve it.
                            May they can do.
                            I only translated what he said.
                            I wish you the best of luck!
