Can anybody upload Cutlass II schematic ?
Cutlass II
I did not use a separate auto switch, just Disc, All metal and momentary pinpoint(re-tune) on one switch. Left the threshold inside and aded a 2 1/2 turn external GB (found the same Tesoro uses). But probably should have done the opposite. Took out the speaker too.
Also replaced all electrolytics with tantalum, a few other leaded caps to mil grade and rewired with Teflon 24 awg.
The negative supply is onl -3V. I always wondered what would happen if that was actually -5V.
Oh, and got me a Troy Super 7 coil for it.
Pinpoint
I did this, with a SP3T switch to not need the separate auto switch. I don't know if Tesoro ever thought of this but makes more sense to me.
Actually I mounted it upside down from this diagram. (down is Pinpoint/Retune).
BTW, the -3 is only -3 because >8 volts would be beyond max volt of the IC.
this bottom side title sure say that cutlass2 and SS2 have one board.Attached Files
