Error .... I'm sorry, ZD2V7 is oriented wrong!
Serbian "Most Wanted"
You made the topic so much about the detector, which is so simple, and which is all known. My first Gold Rover as it so then I called before I did 5godina. Set a pattern for you two tons, which I did 3 years ago and which is 100 percent accurate.
http://www.geotech1.com/forums/image...ilies/wink.gif
I don't have a clue?Originally posted by Ultimate_Haze View PostHi,
There are some differences.Your coil is 0.9mH;2,1ohms/14,72mH;30,6ohms.
And RH coil is 0.9mH;3,9ohms/15,83mH;40,6ohms.
What can you suggest me to try,so I can compensate resistance difference?
Thank.
p.s.I see that there are bad traffic conditions.No matter I can wait.
Use some calculator and calculate possible cap values at TX and RX...
Right now i don't have time to do that, must go now...
Regards!
Thank.
I can't promise soon to record video. Friend with camera is 60km away from me and right now roads are under heavy blizzard, so trafic is interrupted frequently. It is a question of time where he will be able to visit me.
Week...two...or more? I can't tell...
Ivconic.
Can you measure what are resistances of this TS100 coil.
I just measure those on RH coil and they are 3,9ohms/40,6ohms.
Waiting to see this video when you are ready
I will sell my Nexus, and I think this will be the ideal replacement, I will ask and start components, wish me luck, ha, ha, ha.
PD: pcb manufacture of ivconic, Developer No. 1 VLF MD. Ivconic thanks for their work.
Good luck.Originally posted by Pompey View PostI wish you to get this machine working
I will also wind DD38sm coil and try it with the first pcb with LM555.I found that the first pcb is smaller than the last one -it`s only about 7.7/9.4sm.I`ll try it tomorrow may be.
DD38 would be a fantastic coil for coins biger than 25mm.
My 38cm(15") coil detects the soda can at about 1m. All test are on air of course
Hi Pompey.
I found the first problem with sound, it was a fault 100n capacitor. But now the problem is the coils. As i see at Bluemax the Rx signal is about 35degrees rear of the Tx signal. So i must make it to be in phase with tx signal. I will try to late the Rx signal other 330 degrees so to be in phase with the Tx or other 150 degrees and to reverse the winding. But it is not so easy to make it. With the disk potentiometer closed and when i have signal only on the one channel (ferrous), it detect a 30mm coin at 50+cm with the coil no good tuned. This is the reason that i try to make it to work right.
Hi,Geo!My problem with this pcb was a cold solder.I resoldered all the parts and everything is ok now.My handmade coil is 42w 0.56 Tx and 173w 0.25 Rx.LC-meter shows 0.9 /16.6mH .I tried many frequencies and found that it works very well from 7 to 9 khz.Now it works at 7.6khz.For Tx I put 470nf and for Rx -22nf .I can fully reject ferrite,discrimination is very good.I use two KF347=LF347. For 1.3M rezistor I put 3M.Tx is 20v p-p.I have found what is BIAS for.If you adjust GEB with a small ferrite (3sm long,and 8mm diameter)there is a point where ferrite is almost rejected,but there are some cracks.Diskr.pot is 1/3 turned to right.At this place of GEB I can detect very deep but sound was ropy and almost double at the end.By turning the BIAS sound become normal.After that I turned discr. pot to the place where iron pliers were almost fully rejected.Then with a little bit of gold I adjust the fase so detector to detect this bit.This happen when fase pot is fully turned to right.I left detectors working for many hours while I am on work and when I returned to him I can`t understand if it`s still works -no sound,no cracks at all and sensitivity is great.I have not 1 euro,but 1 lev (bg) is detected at 34-35sm when pliers were discriminated.A very nice machine.Now I will try schematic with LM555 these days..
P.S: I`ve forgot to ment -my coil is DD27
