Originally posted by Geo
Serbian "Most Wanted"
Sure, it was result of international cooperation (developed in Bulgaria, modified in Serbia and produced in Greece) cannot be better.
Hi WM6.Originally posted by WM6 View PostGeo, try first with another coil.
I have 3 ready coil and i want to make it to work with them.
They are a 10"DD from MD5002, a BlueMax 950- 9.5" from my Whites XLT and a BlueMax1500 - 15" from Whites for XLT etc. I saw that this simple detector with the 15" coil has better ability to detect a 30mm coin than my Sovereign. So i want to play with it
Thanks Magma.Originally posted by Magma View PostHi Geo
Here are two ideas for a solution that you can try:
Do you know if the waveforms are ok or not??
Also first 2 days the disk worked ok (no perfect but good).
Today i will replace the capacitors for phase shift.
phase
Hi Geo
Here are two ideas for a solution that you can try:Attached Files
Originally posted by Magma View PostI think, you're probably turned to the entrance of the coil in rx or tx.
Hi Magma.
I have a discrimination problem, so if you can help me.
My Disc potentiometer rejects the "no ferrous" objects but not the iron. So with potentiometer full closed i receive a gold or a silver coin very easy, but detects and iron. If i will turn it right then i detect the iron good again but not the gold or silver.
I attach a photo of the out pin1 of LM393 (Geb), one photo od the out pin7 of LM393 (Disk) comparing to Tx signal and oe photo between pin1 and pin7 (Geb - Disc).
I forgot to tell you that i reversed the coil wires without results
I wait your opinion
I can but not now. My digital camera is not recording tone!Originally posted by Ultimate_Haze View PostGood!
Can you make one video showing detection of 1e coin.So we can hear how this work.Might be useful.
What should be the value for R20 with 1mH/15mH coil?1K8 or 3K9?
Thank you.
It is old and obsolete. I must wait one friend to visit me with his camera and we will record the video than (he recorded TGSL testing for youtube with that camera). It will be in next few weeks, i guess..
Good!
Thank you.
Here is photo of one finished SMW. This one is with handmade coil...
I used TGSL front panel for it, beacuse i haven't prepared panels for SMW yet...
Yes its too strange.
Pity that you dont have this coil any more.You would see what I mean.
Maybe there is something inside this coil.But it should work on 7kHz for shore.
So I will try to make my own coil and see if can make it work ok.
68n at TX !??? Hard for me to imagine that!? Are you sure you didn't reversed TX an d RX ? Because 68n at TX does not makes a sence at all...?!?Originally posted by Ultimate_Haze View PostHi,
Thank you.
I will do as you say.
No I dont want fully reject ferrite rod.Just wanna make it work like it should.
I have connected coil the way you describe.
But haven't try more than 520n for TX.
Funny but I can get good detection only with 68n for TX.
I will play with those caps some more.
Have you try to connect this RH coil?And test the performance?What should be expected for 1e coin?
It looks like this is great detector.
Can wait to tune it and see it in action.
No i don't have RH coil anymore, sold it last summer. I have only Excellerators and 25cm TS1000 coil for Musketeer...
Although inductances are same at coils for RH and Musketeer....maybe something else is much different? I really can't tell what could be the problem.
Thank you.
"...Same thing can be done here. I did not put it on schematic. ..."
There are some types of so "soft" soils where is desireable to search with a bit more "unleashed" phase at detector, so as i noticed.
Doing this way you can locate much deeper items than usuall (it is advisable to search without Disc at some terrains to locate extremly deep items).
That's why i didn't included extra resistance in serie with Disc pot to provide full ferrie rejection at minimal Disc preset.
OK, i could use extra switch than, but i simply didn't cose wanted to keep design as simple as possible and less commands on front panel too.
